Is two default routes possible on F5 without using route domain?
Hi All,
We have a deployment on a client, Viprion with 2 vCMP guests, They have 3 pools of servers, each pool with different VLANs. Their gateway is the 3 self IPs of F5. They wanted to have 3 virtual servers with different VLANs/Subnet. If the backend servers needed to communicate with another device in the data center, we need to have 3 default routes from the F5. Is this possible without using route domain?
Thanks in advanced
- stan_piron
Cumulonimbus
Can you give example of your need???
Do you want to do Policy Based Routing for a forwarding VS?
If you want to do PBR for a forwarding VS, you can create an irule or create 3 Performance Layer VS with:
- Destination Address 0.0.0.0/0
- translation disable (convert a performance Layer 4 VS to forwarding but with pool used as Gateway pool. disabled by default when destination is a network)
- protocol Any
- Source VLAN or Source address different for each VS
- default pool containing gateway
Stanislas
