Is There a "Key" to Rewriting TMSH Commands as RESTful Calls? +Example
Hiya,
I'm running this command remotely to get a pool member's active connections, but it's a) awfully kludgy and b) I'd like get the results from the RESTful API:
ssh $ID@$F5_HOST "show /ltm pool $POOL members { $POOL_MEMBER } default" | awk '/| Current Connections/ {print $(NF-1)}'
Awk grabs this line and returns the "ServerSide" stats for that pool:
| Current Connections 0 -
I've had some luck constructing URIs to pass into cURL from other TMSH commands, but I haven't really figured out a pattern I can follow to create arbitrary API requests. Do any of you have a handy trick or rule to follow?
Worst case, how the heck can I pull specific Traffic and Connection Queue statistics for pools and pool members via the API? Thanks?
- Kevin_K_51432Historic F5 Account
Greetings, I've had good luck using most of the Rest API by simply appending "stats" to the end of a query. I'm by not means an expert here, but I do use Rest quite often due to its simplicity:
So I would grab the stats for a pool named "default_gw" using the following:
curl -sk -u admin:admin https://172.24.64.39/mgmt/tm/ltm/pool/~Common~default_gw/members/~Common~10.12.23.27:0/statsThe output would be similar to:
"generation":1 "selfLink":"https://localhost/mgmt/tm/ltm/pool/~Common~default_gw/members/~Common~10.12.23.27:0/stats?ver=12.0.0" "entries":{"https://localhost/mgmt/tm/ltm/pool/~Common~default_gw/members/~Common~10.12.23.27:0/~Common~10.12.23.27:0/stats":{"nestedStats":{"kind":"tm:ltm:pool:members:membersstats" "selfLink":"https://localhost/mgmt/tm/ltm/pool/~Common~default_gw/members/~Common~10.12.23.27:0/~Common~10.12.23.27:0/stats?ver=12.0.0" "entries":{"addr":{"description":"10.12.23.27"} "connq.ageEdm":{"value":0} "connq.ageEma":{"value":0} "connq.ageHead":{"value":0} "connq.ageMax":{"value":0} "connq.depth":{"value":0} "connq.serviced":{"value":0} "curSessions":{"value":0} "monitorRule":{"description":"/Common/gateway_icmp (pool monitor)"} "monitorStatus":{"description":"up"} "nodeName":{"description":"/Common/10.12.23.27"} "poolName":{"description":"/Common/default_gw"} "port":{"value":0} "serverside.bitsIn":{"value":175344} "serverside.bitsOut":{"value":215808} "serverside.curConns":{"value":0} "serverside.maxConns":{"value":10} "serverside.pktsIn":{"value":334} "serverside.pktsOut":{"value":240} "serverside.totConns":{"value":94} "sessionStatus":{"description":"enabled"} "status.availabilityState":{"description":"available"} "status.enabledState":{"description":"enabled"} "status.statusReason":{"description":"Pool member is available"} "totRequests":{"value":0}}}}}}- syncretism
Stats! I knew I had that somewhere in my notes. This is great - I'm passing the JSON object to jq and watching the number of connections in my script. Just what I needed. Thanks so much!
I was equally happy at discovering this one =) You're very welcome, glad this was helpful!
