Is it possible to load UCS from a BIGIP5000 platform to a vCMP guest with same version?
HI Devcentral Peeps,
This is what i planned to do, create the VLANs on host level, create the vcmp guest with the same hostname and restore the UCS from bigip appliance going to that vCMP guest.
Thanks!
- stan_piron
Cumulonimbus
what is the "same version"?
Which module do you want to restore?
To restore a backup on another platform, the UCS load must be done with tmsh.
In version 12.1.x, there is an option with
to migrate without platform specific configurationplatform-migratehttps://support.f5.com/csp/article/K82540512
this command is only supported with LTM and DNS.
the main goal of this command is to import LB configuration and not VLAN and self IP. VLAN must not be imported in VCMP because VLAN configuration is done on the VCMP host and enabled en guests.
