Michael_Mangret
Apr 17, 2007Is it possible in 4.x...
to search the incomming request for a paticular string, then either discard or loadbalance to a paticular pool. I am unable to find any reference material on rule syntax for 4.5.x. If anyone knows where I might find a document that has a syntax list for rules in 4.5, that would be great as well.
Thanks,
MM
- The documentation for v4.x iRules are in the product user manuals available on ask.f5.com. These code samples are from the following link
https://tech.f5.com/home/bigip/manuals/bigip4_6_2/bigip4_6_2ref/BIGip_rules.html1208927
Click hererule my_rule { if (tcp_content contains "XYZ") { use pool xyz_servers } else if (substr(tcp_content(100), 50, 3)) == "ABC" { use pool abc_servers } else { use pool web_servers } }rule my_rule { if (http_content contains "ABC") { use pool http_pool } else if (http_content_collected < 20) { accumulate } else { discard } }
There are a couple of other examples in there but this should get you started.
-Joe
