Andrew_Smith_16's avatar
Andrew_Smith_16
Jun 15, 2016
Solved
iRule with pool status and maintenance page
I have several iRules that currently have 20+ switch elements that matches on a specific uri which takes you to a particular pool. I now need to display a maintenance page if there are no members in the pool. Is there an easier way to achieve this without adding an 'IF' statement in for each pool? I assume I could replace status and the maintenance page redirection with a process but it still seems long winded - probably comes from a poor design but partly dictated by the customer. Thanks in advance.
e.g.
  switch -glob [HTTP::uri] {
    "/foo1" { if {[active_members pool1] <1}{
      switch [HTTP::uri] {
        "/logo.jpg" {
          HTTP::respond 200 content [ifile get logo.gif] "Content-Type" "image/gif"
        default {
          HTTP::respond 200 content [ifile get error.html] "Content-Type" "text/html"
    } else {pool pool1 }}
    "/foo2" { if {[active_members pool2] <1}{
        "/logo.jpg" {
        default {
} else {pool pool2 }}
    "/foo3" { if {[active_members pool3] <1}{
        "/logo.jpg" {
        default {
} else {pool pool3 }}
  • Hi,
    Here is an irule example that do the same as your own irule :
        if { [active_members pool1] <1 or [active_members pool2] <1 or [active_members pool3] <1} {
            if { [URI::basename [HTTP::uri]] eq "logo.jpg" } {
                "/foo1*"  { pool pool1 }
                "/foo2*" { pool pool2 }
                "/foo3*" { pool pool3 }
  • Hi,
    • Andrew_Smith_16's avatar
      Andrew_Smith_16
      Thanks very much. I made a mistake in my example as well but this looks a lot cleaner.
  • Hi,
      Andrew_Smith_16
