awan_m's avatar
awan_m
Apr 02, 2024
Solved
iRule LX replacement on bigip-Next
Hi all - we use ILX on our current bigip platform and wanted to understand what will be alternate for it in the NEXT platform.
my use case is - when a HTTP request comes in the F5 extracts some information out of the request along with the client IP .
the ILX part makes a REST call to an external URL with that information . if it returns a 200 response - the HTTP request is allowed to move forward to the pool . if a 403 is returned from the external service a reset is sent back.
how can i do the same in bigip-Next - as we have nodejs code performing this tak.
  • Fortunately BIG-IP Next Access will have this "query an arbitrary HTTP endpoint" functionality natively in upcoming versions in both per-request and per-session contexts. A quick check shows that you can write custom behaviors for different response codes so you'd be able to do something different if you get a 200 vs a 403.
    As you're probably aware, BIG-IP APM has this native functionality only in a "per request" context.
  • awan_m - if this resolved your question please consider Mark As Solution to help other community members find help faster/easier. Thanks, Lief
