ivanchen0503_36
Mar 28, 2019iRule how to use rewrite by same token ?
Im not sure about F5 iRule can or not solve this solution , i need rewrite to , only rewrite "iphone.aspx" to "mobile" this key point and the token number need same .. anyone can help this ? thanks .
- Samir_Jha_52506
Noctilucent
Yeah you can do with irule. Try below..
when HTTP_REQUEST { set id [URI::query [HTTP::uri] token] if { [HTTP::uri] starts_with "/iphone.aspx" } { HTTP::redirect "https://www.abc.com/mobile?token=$id" } } - stan_piron
Cumulonimbus
Do you want to rewrite or redirect?
For a rewrite:
when HTTP_REQUEST { if { [HTTP::path] equals "/iphone.aspx" } { HTTP::path "/mobile" } }For a redirect
when HTTP_REQUEST { if { [HTTP::path] equals "/iphone.aspx" } { HTTP::redirect [join [list "/mobile" [HTTP::query]] "?" ] } }Join command is there to add question mark only if query string is not empty
