Ashu_Aggarwal's avatar
Jan 27, 2020
irule help - disable persistence
I have a VS configured with session cookie persistence profile. So all the requests from users & middleware receive session cookie. users receives session cookie is fine but all the requests from middleware routed to only one server in load balancing pool which is not desired. I need to configure a irule so that all the POST messages from middleware should not receive a cookie & get loadbalanced more efficiently. This is the i-rule i came up with. Would it work ?
when CLIENT_ACCEPTED {
     switch [IP::client_addr] {
       "10.27.15.231" { persist none }
       "10.27.15.236" { persist none }
       "10.27.15.238" { persist none }
  • That should work, although you might want to create a data-group of type address, and use class match
        if {[class match [IP::client_addr] equals "middleware-ip_dg"]} {
          persist none
