Dan_DeVlieger's avatar
Dan_DeVlieger
Sep 19, 2019
iRule for Setting Server Side SSL
The iRule below is working for the most part, the setting of the server side SSL profile is the section that is failing we are getting SSL errors upon connecting. This error occurs whether we apply the same profile as part of the VIP configuration also.
when called the section to set the serverside SSL is failing, specifically the following commands
 set SSL::enable
 set SSL::profile TEST-SERVERSIDE-SSL-PROFILE
 What are we missing to get this to work?
 set CALL_SERVERSIDE_SSL 0
 log local0. "Request: [HTTP::host]"
 if {[HTTP::host] starts_with "siteA.mysite.com" }{
  if {[active_members SITEA-9032-POOL] < 1} {
    log local0. "Using pool SO-SORRY-80-POOL"
 else {
   log local0. "Using pool SITEA-9032-POOL"
* elseif {[HTTP::host] starts_with "siteB.mysite.com" }{
  if {[active_members SITEB-PROD-443-POOL] >= 1} {
    log local0. "Using pool SITEB-PROD-443-POOL"
    persist source_addr
    set CALL_SERVERSIDE_SSL 1
    pool SITEB-PROD-443-POOL }
 else {
elseif {[HTTP::host] starts_with "siteC.mysite.com" }{
    if {[HTTP::uri] starts_with "/ca/prd/"}{
      log local0. "Using pool SITEC-PROD-80-POOL"
      persist source_addr
    elseif {[HTTP::uri] starts_with "/ca/stg/"}{
      log local0. "Using pool SITEC-STG-80-POOL"
      persist source_addr
    else reject
 elseif {[HTTP::host] starts_with "siteD.mysite.com" }{
  log local0. "Using pool SITED&E-80-POOL"
 elseif {[HTTP::host] starts_with "siteE.mysite.com" }{
 else {
   log "No header match found"
   reject
when SERVER_CONNECTED {
 if { $CALL_SERVERSIDE_SSL == 1 }{
 log local0. "Setting Serverside SSL $CALL_SERVERSIDE_SSL"
 set SSL::enable
 else {
 log local0. "Not using Serverside SSL $CALL_SERVERSIDE_SSL"
 set SSL::disable
  • Hi Dan DeVlieger,
    You shouldn't use "set" command before ssl::disable, ssl::enable and ssl::profile.
    	if { $CALL_SERVERSIDE_SSL == 1 } {
    		SSL::enable
    	else {
    		SSL::disable
