upendra_126737
Sep 16, 2015iRule for HTTPS
please help me to write an iRule for no-cache for https traffic without providing http profile.
- VernonWells
Employee
Are you offloading TLS on the BIG-IP? And are you trying to add the following headers toward the client?
Cache-Control: no-cache, no-store, must-revalidate Pragma: no-cache Expires: 0If so, why are you trying to avoid the use of the http profile? This could be done without it, but it is much more complicated because you will have to manually process the data stream in the CLIENT_DATA event. In this case, you'll probably need to use the
profile, aSTREAM
substitution rule to remove the three headers above, then anotherSTREAM
substitution to substitute them in where the first instance ofSTREAM\r\n\r\nis found. Among other things, this'll be slower than the
primitives for accomplishing the equivalent.HTTP::
