Martin_Kaiser_1
May 25, 2011iRule error in F5's MS Exchange 2010 deployment guide V2.1?
hi guys,
I'm struggling with MS Exchange 2010 load balancing, especially with authentication issues. The f5 provided deployment guide (which is currently being updated every few days) isn't quite helpful at all, especially since they decided to have include only instructions on how to use those pesky wizards in the LTM web GUI...
http://www.f5.com/pdf/deployment-guides/f5-exchange-2010-dg.pdf
However, the newest version includes an iRule for turning off oneconnect transformations during autodiscovery. The instructions concerning that iRule read as follows:
Single virtual server
If you chose a single virtual server, you must add the a small iRule to the secure Autodiscover virtual server created by the template that removes the OneConnect profile only from relevant service. You must first create the iRule and then associate it with the Autodiscover virtual server. To create the iRule
1. On the Main tab, expand Local Traffic and then click iRules.
2. Click the Create button.
3. In the Name box, type a name. In our example, we type autodiscover-irule.
4. In the Definition section, copy the following iRule
when HTTP_RESPONSE {
if { [HTTP::header values WWW-Authenticate] contains "Negotiate" } { ONECONNECT::detach disable }
Now, as I understand ONECONNECT::detach, in order to achieve the de-activation of oneconnect, that line should read ONECONNECT::detach ENable instead of DISable. Do you agree?
Regards
Martin
- hoolio
Hi Martin,
I think the idea is that you prevent OneConnect from detaching the serverside connection for this client and allowing it to be reused for other client connections by calling 'ONECONNECT::detach disable'.
Michael Koyfman suggested this fix in a recent thread. As he's tested this quite extensively, I think 'ONECONNECT::detach disable' is correct.
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/aff/25/afv/topic/aft/1177067/afc/1249651/Default.aspx
Aaron - Martin_Kaiser_1
Hi Aaron.
Understood.
IMHO, the trouble with that deployment guide is, it does not even try to explain the settings, it just tells you where to enter which information (why vs. how it is done). When you are experiencing trouble afterwards (and aren't really deep into that exchange/microsoft stuff), you don't know where to start troubleshooting or how it's even supposed to work.
However... many thanks for pointing out again!
Martin - hoolio
Yeah, I think all of the manuals could use a lot more explanatory text which covers the whys not just the buttons to click. You could try opening a case with F5 Support to provide this kind of feedback. Concrete examples definitely help.
Aaron
