Peter_71504
Jul 04, 2011irule & advanced routing module
Have been looking into advanced routing modules.
Would like to change cost of a route (or only send the route) for a vip address based on what nodes is up i.e.
if node a is up and b is down send route as normal
if node a is down and b is up make route higher cost (or do not send route)
From what I read, Route health injection is based on if vip is up so not exactly what I require.
I know I can check node status with irule. Can I influence advanced routing module with irule?
A link to an example irule and routing would be great.
thanks
Peter
- The_Bhattman
Hi Peter,
Have you looked into the following Video Blog. I am not sure if this entirely answers your problem but it could give you an idea of what it can do. However, I don't believe you can manipulate the routing in the manner you speak of directly with an iRule. It probably can be manipulated with some custom monitors which could trigger a shell script and inturn the shell script could make some route changes based on that.
Here is the link to the video
http://devcentral.f5.com/weblogs/dctv/archive/2008/06/26/3400.aspx
I hope this helps,
Bhattman
