DMA_95966
Jul 13, 2012Inactive node taking traffic
Hello All,
I have one VIP setup in which i can see node is down , but it still taking traffic. As i know e default behavior of F5 HLB, when it detects that a node is down, is to route new requests to a known good node and let existing sessions continue to go to the known bad node . So Is there any way that to stop the traffic immediately. Is any irule or any specific setting that i can apply for desired result ?
Thanks, Deepak
- nitass
Employee
can you try LB::status and reject command?
LB:status wiki
https://devcentral.f5.com/wiki/iRules.lb__status.ashx
reject
https://devcentral.f5.com/wiki/irules.reject.ashx - hoolio
Another option is to set the 'action on service down' pool setting to 'reject' so TMM will send a TCP reset when the pool member is marked down by a monitor.
Aaron - DMA_95966
Hello Hoolio,
thanks for the reply.
could you please explain ? Do I need to create irule for this . - DMA_95966
Issue: VIPs no longer passing external public IPs to servers
I have vip setup , and using tool we are monitoring public ips form which traffic is coming to server. Since few days its stop working .I took tcpdumo using server ip and using tool I found that its showing only one ip form which traffic is coming to server. when I checked for that ip , I can see that ip is configured as snat. Any idea about this ? - DMA_95966
