Prabhat_Karki_3's avatar
Prabhat_Karki_3
Historic F5 Account
Jun 15, 2017
Solved
iControl REST for module provisioning
Hello, I'm trying to use iControl REST to provision the moduleon BigIP 12.1.2 According to iControl API doc /tm/sys/provision accepts PUT method. Below is my REST call, and I'm getting 403 forbidden error
curl -ksi -u "admin:" https://:/mgmt/tm/sys/provision \ -H "Content-Type: application/json" \ -H "Accept: application/json" \ -X PUT -d ' {"name":"afm", "level":"nominal"}'
HTTP/1.1 403 Forbidden Date: 15 Jun 2017 16:07:40 UTC Server: X-Frame-Options: SAMEORIGIN Strict-Transport-Security: max-age=16070400; includeSubDomains Pragma: no-cache Cache-Control: no-store, no-cache, must-revalidate Expires: -1 Content-Length: 109 Content-Type: application/json Allow: REMOTEROLE: 0 Local-Ip-From-Httpd: 11.0.0.166 Session-Invalid: true X-Forwarded-Server: localhost.localdomain X-Forwarded-Proto: http REMOTECONSOLE: /sbin/nologin X-Forwarded-Host: 11.0.0.166 X-Content-Type-Options: nosniff X-XSS-Protection: 1; mode=block Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; img-src 'self' http://127.4.1.1 http://127.4.2.1
Am I missing anything?
  • Resolved Instead of PUT, method PATCH needs to be used and needs to add the module name in the URL Here is the working command
    curl -ksi -u "admin:admin" https:///mgmt/tm/sys/provision/afm -H "Content-Type: application/json" -H "Accept: application/json" -X PATCH -d ' {"name":"afm", "level":"nominal"}'
    HTTP/1.1 200 OK Date: 15 Jun 2017 19:52:14 UTC Server: X-Frame-Options: SAMEORIGIN Strict-Transport-Security: max-age=16070400; includeSubDomains Pragma: no-cache Cache-Control: no-store, no-cache, must-revalidate Expires: -1 Content-Length: 218 Content-Type: application/json Allow: REMOTEROLE: 0 Local-Ip-From-Httpd: Session-Invalid: true X-Forwarded-Server: localhost.localdomain X-Forwarded-Proto: http REMOTECONSOLE: /sbin/nologin X-Forwarded-Host: X-Content-Type-Options: nosniff X-XSS-Protection: 1; mode=block Content-Security-Policy: default-src 'self' 'unsafe-inline' 'unsafe-eval'; img-src 'self' http://127.4.1.1 http://127.4.2.1
    {"kind":"tm:sys:provision:provisionstate","name":"afm","fullPath":"afm","generation":549,"selfLink":";:
  • Prabhat_Karki_3's avatar
    Prabhat_Karki_3
    Historic F5 Account
