Pushkar_73645
Feb 26, 2012icontrol call for 10.1.0
I am trying to find out soap calls for following.
1) Any active user sessions
2) Find out sync status in an active/active configuration
I was looking through icontrol documentation but could not find any appropriate calls.
any icontrol calls that i can use?
Thanks,
Pushkar
- Hamish
Cirrocumulus
Mmm... I think there's a db variable for that. Let me check when i get off the tube
H - Hamish
Cirrocumulus
It's a DB call. There's s perl program to so this in the codeshare at https://devcentral.f5.com/wiki/iControl.walkF5Stats.ashx that i wrote a few years back.
the relevant code (Apologies for the line numbers) is---------------------------------------------------------------------------- 0359 getConfigSyncStatus 0360---------------------------------------------------------------------------- 0361sub getConfigSyncStatus { 0362 my $dbh=$_[0]; 0363 my $dev=$_[1]; 0364 my $t0=[gettimeofday]; 0365 0366 my $devID=$dev->{ID}; 0367 @dbKeys = ( 0368 "configsync.autodetect", 0369 "configsync.localconfigtime", 0370 "configsync.peerconfigtime", 0371 "configsync.localsyncedtime", 0372 "configsync.state"); 0373 (@dbValues) = &getDBVariable($dev, @dbKeys); 0374 0375 my $autodetect; 0376 0377 dbprint "check " , gmtime($dbValues[1]); 0378 0379 print "CONFIG SYNC STATUS --\n"; 0380 if ( "disable" eq $dbValues[0] ) { 0381 Standalone 0382 dbprint " Status: disabled\n"; 0383 dbprint " Last change (Self): ", strftime("%Y%m%dT%H%M%SZ", gmtime($dbValues[1])), "\n"; 0384 $autodetect=0; 0385 } else { 0386 HA Pair 0387 $autodetect=1; 0388 dbprint " Status: $dbValues[4]\n"; 0389 dbprint " Last change (Self): ", strftime("%Y%m%dT%H%M%SZ", gmtime($dbValues[1])), "\n"; 0390 dbprint " Last change (Peer): ", strftime("%Y%m%dT%H%M%SZ", gmtime($dbValues[2])), "\n"; 0391 dbprint " Last Configsync: ", strftime("%Y%m%dT%H%M%SZ", gmtime($dbValues[3])), "\n"; 0392 } 0393 get the current f5deviceSync information. This creates blank info if one doesn't exist already... 0394 my $f5dS=getDBDeviceSync($dbh, $devID); 0395 0396 Update the information... If it's changed. And set an alert or warning (In DB only?)... 0397 my $localcfgtime=strftime("%Y%m%dT%H%M%SZ", gmtime($dbValues[1])); 0398 my $peercfgtime=strftime("%Y%m%dT%H%M%SZ", gmtime($dbValues[2])); 0399 my $localsynctime=strftime("%Y%m%dT%H%M%SZ", gmtime($dbValues[3])); 0400 0401 my ($statusCode)=($dbValues[4] =~ /(\d+) \-/); 0402 0403 dbprint "getConfigSyncStatus: Status code of $statusCode from $dbValues[4]\n"; 0404 0405 if(($localcfgtime ne $f5dS->{localcfgtime})||($peercfgtime ne $f5dS->{peercfgtime})||($localsynctime ne $f5dS->{localsynctime})) { 0406 dbprint " Status Change. Updating DB\n"; 0407 my $updatestr="update f5deviceSync set autodetect=$autodetect,localcfgtime='$localcfgtime',peercfgtime='$peercfgtime',localsynctime='$localcfgtime',state='$dbValues[4]' where id=$devID"; 0408 dbprint "getConfigSyncStatus: SQL [$updatestr]\n"; 0409 0410 my $update=$dbh->prepare($updatestr); 0411 0412 0413 $update->execute; 0414 0415 0416 } 0417 my $elapsed=tv_interval ( $t0 ); 0418 log_action($elapsed, 0, "getConfigSyncStatus", ""); 0419 0420 $t0=[gettimeofday]; 0421 0422 Not very useful... This overwrites the last one... Needs fixing... 0423 my $updatestr="update cluster,cluster_device set insync=$statusCode where cluster.clusterid=cluster_device.clusterid and cluster_device.deviceid=$devID"; 0424 dbprint "getConfigSyncStatus: SQL [$updatestr]\n"; 0425 0426 my $update=$dbh->prepare($updatestr); 0427 $update->execute; 0428 0429 $updatestr="update device set sync=$statusCode where id=$devID"; 0430 $update=$dbh->prepare($updatestr); 0431 $update->execute; 0432 0433 my $elapsed=tv_interval ( $t0 ); 0434 log_action($elapsed, 0, "getConfigSyncStatus", "$updatestr"); 0435 0436} - Pushkar_73645
Thanks Hamish.
I was able to get config sync db varialbe with php.
Any call which can provide me information about users which are already logged in?
-Pushkar - Can you explain what you mean by "already logged in". Are you referring to GUI/iControl users that have authenticated connections to the admin interface? If so, I don't believe that's available.
-Joe - Pushkar_73645
Yes, I am looking for list of users who is already logged on using web gui. We are trying to find if anyone else is logged in before making any changes.
Thanks for looking into this.
-Pushkar
