Python script to proxy iControl REST calls
Problem this snippet solves:
I have a customer who has an automation platform written in Perl. This tool has a web front end that serves as a self-service portal for operations folks to perform some tasks on back end systems in a controlled, automated manner. The customer wanted a way to make iControl REST calls without a tremendous amount of effort, so we came up with the idea of having him call a Python script, along with command line arguments, that would be passed to the BIG-IP and responses handed back. This is the script I gave him to do so.
How to use this snippet:
Run the command with no arguments from the command line to access the help section of the code.
Code :
#!/usr/bin/env python3
import argparse,json,requests
from requests.packages.urllib3.exceptions import InsecureRequestWarning
requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
def icontrol_get(host,username,password,path):
apiCall = requests.session()
apiCall.headers.update({'Content-type':'application/json'})
apiCall.auth = (username,password)
apiUri = 'https://' + host + path
try:
apiResponse = apiCall.get(apiUri,verify=False)
except requests.exceptions.RequestException as e:
print('{"responseStatus":"error","action":"get","host":"' + host + '","username":"' + username + '","path":"' + path + '","errorMsg":"' + str(e) + '"}')
return(apiResponse.text)
def icontrol_post(host,username,password,path,api_payload):
try:
apiResponse = apiCall.post(apiUri,verify=False,data=json.dumps(api_payload))
print('{"responseStatus":"error","action":"post","host":"' + host + '","username":"' + username + '","path":"' + path + '"},"payload":"' + api_payload + '","errorMsg":"' + str(e) + '"}')
def icontrol_put(host,username,password,path,api_payload):
try:
apiResponse = apiCall.put(apiUri,verify=False,data=json.dumps(api_payload))
print('{"responseStatus":"error","action":"put","host":"' + host + '","username":"' + username + '","path":"' + path + '"},"payload":"' + api_payload + '","errorMsg":"' + str(e) + '"}')
def icontrol_patch(host,username,password,path,api_payload):
try:
apiResponse = apiCall.patch(apiUri,verify=False,data=json.dumps(api_payload))
print('{"responseStatus":"error","action":"patch","host":"' + host + '","username":"' + username + '","path":"' + path + '"},"payload":"' + api_payload + '","errorMsg":"' + str(e) + '"}')
def icontrol_delete(host,username,password,path):
try:
apiResponse = apiCall.delete(apiUri,verify=False)
print('{"responseStatus":"error","action":"delete","host":"' + host + '","username":"' + username + '","path":"' + path + '"},"errorMsg":"' + str(e) + '"}')
# Parse the command line arguments
cmdargs = argparse.ArgumentParser()
cmdargs.add_argument('--host',action='store',required=True,type=str,help='ip of BIG-IP REST interface, typically the mgmt ip')
cmdargs.add_argument('--username',action='store',required=True,type=str,help='username for REST authentication')
cmdargs.add_argument('--password',action='store',required=True,type=str,help='password for REST authentication')
cmdargs.add_argument('--uri',action='store',required=True,type=str,help='the uri of the resource')
cmdargs.add_argument('--action',action='store',required=True,type=str,help='the HTTP action (GET, PUT, POST, PATCH, DELETE)')
cmdargs.add_argument('--payload',action='store',required=False,type=json.loads,help='the payload for PUT, POST and PATCH operations')
parsed_args = cmdargs.parse_args()
host = parsed_args.host
username = parsed_args.username
password = parsed_args.password
uri = parsed_args.uri
action = str(parsed_args.action).lower()
payload = parsed_args.payload
# Proxy the REST call
if action == 'get':
response = icontrol_get(host,username,password,uri)
if action == 'put':
response = icontrol_put(host,username,password,uri,payload)
if action == 'post':
response = icontrol_post(host,username,password,uri,payload)
if action == 'delete':
response = icontrol_delete(host,username,password,uri)
if action == 'patch':
response = icontrol_patch(host,username,password,uri,payload)
print(response)Tested this on version:
12.1Published Aug 13, 2019
Version 1.0G-Rob
Employee
F5 Solutions Engineer focused on cloud, automation, modern apps and excellent customer-focused service.No CommentsBe the first to comment
