ykkim
May 15, 2012iControl application work takes too long.
Hi
I have a time issue.
My BIG-IP has:
241 virtual servers,
242 pools(each of which has several members in it),
222 nodes.
My iControl Java application scans the BIP-IP's object information periodically. It's operation steps and times are as follows:
(A) virtual server list --> 3sec
(B) virtual IP/Port list of given virtual server list(A) --> 5sec
(C) persistence profile list of (A) --> 5.6sec
(D) default pool list of (A) --> 2sec
(E) status of (A) --> 6.4sec
(F) pool list --> 1.6sec
(G) lbmethod list of (F) --> 2sec
(H) member definitions of (F) --> 30sec
(I) node list --> 1.4sec
In each step, I called the API function once and got the results in an array. That means there is no loop work. It takes 50 ~ 70 seconds from (A) to (I).
I think this scanning time is too long. Is 50~70 seconds normal for this scale? Or do you have some check points to advise?
Thanks.
YK Kim of Openbase
