ScottJHarris_82's avatar
ScottJHarris_82
9 years ago
Solved
12.1.2 Issue - iControl RestAPI
Hello
I upgraded a pair of vCMP Guest from 11.6.1 to 12.1.2.
There is a script local to the vCMP Guesta that moves a VLAN to a specific Route-Domain. (this has worked fine for years on 11.6.1). However after the upgrade, this script now fails with an error 400.
Error Code ""code":400,"message":"script did not successfully complete, status:1","errorStack":[],"apiError":26214401}
RestAPI Call curl -sk -u username:password -X POST -H "Content-Type: application/json" -d '{"command":"run","utilCmdArgs":"move_vlan_route_domain_script Route_Domain_ID VLAN_ID add"}'
move_vlan_route_domain_script details
{ proc script::run {} { if { $tmsh::argc !=4 } { puts "a routeDomainName and a vlanName must be provided" exit 123 } set zero [lindex $tmsh::argv 0] set routeDomain [lindex $tmsh::argv 1] set vlanName [lindex $tmsh::argv 2] set command [lindex $tmsh::argv 3] puts "tmsh::modify /net route-domain $routeDomain vlans $command { $vlanName }" tmsh::modify /net route-domain $routeDomain vlans $command "{ $vlanName }" exit 0 } }
Any assistance, work-arounds..etc would be greatly appreciated.
Thank-You Scott
  • So the answer is related to TCL syntax.
    It's possibly bug or enforcing a syntax structure previously not enforced but we remove the puts command and the script ran as expected.
    Thanks Scott
    Thanks Scott
  • Having issues as well moving from 11.6 to 12.1.2 with connections gathering
    /mgmt/tm/sys/performance/connections/stats
