maxas_59256's avatar
maxas_59256
Mar 25, 2012
HTTP:uri NOT contain
Can someone help me with following?
I am trying to add additional condition (http:query not contain) after the 'and'.
This way it doesn't work:
if { [[string tolower [HTTP::path]] contains "/abc/" || [string tolower [HTTP::path]] contains "/abc?"] && [not[string tolower [HTTP::query]] contains "def"]}
Thanks!
  • hoolio's avatar
    hoolio
    Hi Maxas,
    What's the order of precedence you want? A || B && C isn't clear to me. Also, what are you trying to do with the ? in the second check? Are you trying to match a literal ? or any single character? Here's a guess at what you're trying to do:
    if { ([string tolower [HTTP::path]] contains "/abc/" || [string tolower [HTTP::path]] contains "/abc?"]) and not ([string tolower [HTTP::query]] contains "def")}
    Aaron
  • Hoolio,thank you for quick and helpful response!
    I am trying to find some string like "/max/" or "/max?" in request URL in http:path , and make sure that there is no string "maxas" in the same request ,in http:uri.
    If meet these conditions - perform redirect.
    Anyway,it works now.
    Thanks again!
