Marco_Bayarena_
Altostratus
Aug 22, 2012HTTPS Redirect to another HTTPS domain using same VS.
I have a VS configured with a Client SSL profile for domain www.newsite.com. We are trying to migrate off an old domain name called www.oldsite.com that was using the same VS. Originally the Client Profile was set to www.oldsite.com certificate. We changed the profile to use the SSL certificate for www.newsite.com.
I would like for when someone browses to https://www.oldsite.com to redirect to https://www.newsite.com.
When I create the iRule,
if { [HTTP::host] equals "www.oldsite.com" }
HTTP::redirect "https://www.newsite.com"
It doesn't seem to trigger because the browser is looking for the certificate for www.oldsite.com. It works when it is an HTTP request to www.oldsite.com. It fails when it is HTTPS.
Is there a way to make this rule or some other method to trigger immediately before the browser checks the common name of the cert?
- nathe
Cirrocumulus
Marco
I think the only solution to this would be a SAN certificate, including both domains, on the VS.
Alternatively could you change the IP address of the oldsite domain and point it to a different VS (with the oldsite SSL profile/certificate) which does a redirect to the new domain name / VS?
Rgds
N - nitass
Employee
this is some information about sni.
sol13452: Configuring a virtual server to serve multiple HTTPS sites using TLS Server Name Indication (SNI) feature
http://support.f5.com/kb/en-us/solutions/public/13000/400/sol13452.html
Multiple Certs, One VIP: TLS Server Name Indication via iRules by Colin
https://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/1086451/Multiple-Certs-One-VIP-TLS-Server-Name-Indication-via-iRules.aspx - Marco_Bayarena_
Altostratus
I had a feeling I would have to create another VS and assigned the old SSL cert to that. Thanks for the responses.
