DH's avatar
DH
Jan 21, 2020
HTTPS Monitor Questions
How is certificate verification done? Will monitor fail if server has invalid certificate?
I am trying to setup a HTTPS Monitor for a website. In Postman I have tested the the 'GET" as follows 'https://XXXXXXX.com/YYYYYYYYYY/ZZZZZZ HTTP/1.1\r\nHost:xxxxxxxxxx.com\r\nConnection: Close\r\n\r\n' It successfully returns a Status of 200 OK
I have created the following Monitor in F5. This is a Production site so want to double-check accuracy for monitor before applying.
Send String - https://xxxxxxxx.com/yyyyyyyy/zzzzzz HTTP/1.1\r\nHost: xxxxxxxxxx.com\r\nConnection: Close\r\n\r\n
Receive String - 200 OK
Should the above Monitor work or should I change something in it before testing further on F5?
Any comments would be appreciated.
