Alessio_Antolin's avatar
Alessio_Antolin
Oct 18, 2018
Solved
How to return traffic from a vCMP towards two firewalls
Hi all, I have a Viprion with a public vCMP configured, it's connected through point-to-point to firewall.
Now I should connect the same vCMP to another public firewall.
Default gateway is firewall-1. What is the best way to return the traffic towards firewall-1 or firewall-2?
(PBR? Auto Last Hop? I don't have available core, I can't create new vCMP).
Thanks for support!
  • HI
    Maybe a route domain will work for you, each firewall will be in each route domain with its own default route.
  • HI
  • Assuming that the firewalls are on the client side of the F5, Autolasthop will deal with this by default. If it's on the server side then you have to make sure the same traffic goes to each firewall - use routing to separate it across the firewalls.
