Daniel_104432's avatar
Daniel_104432
Sep 19, 2011
How to read a string + value from a data group list
Hello there,
i've got some trouble with a datagroup list. We are using a lot of lists to match strings against client host requests but now I want to use the value of the matched string for a redirect destination.
So in detail i want to do something like this:
1. A client asks for bla.foobar.org
2. The Bigip is getting the request and is matching it against the data group list foobar_list.
3. The host matches and the bigip is doing a redirect to "www.foobar.org/bla"
class foobar_list {
"bla.foobar.org" { "www.foobar.org/bla" }
The reason I want to do it like this is to get away from one irule per redirect. We have way to much irules only for simple redirects. But I don't understand how to use the value.
I hope something like this is working:
if { [matchclass [HTTP::host] contains $::foobar_list] }
HTTP::respond 301 Location [vlaue of bla.foobar.org]
I only need to know how to get the value :)
thanks in advance.
  • Hi Daniel,
    I created an example for you. In my example I capture the "-value" of a matching "-name" and store it in a variable. In the if statement, if a match was found and the value is not empty then it will redirect to the location.
    I am providing the Data Group and the iRule so that you can make modifications and test with hit.
    class string_value_test_group {
          "/foo" { "http://www.yahoo.com" }
          "/foofoo" { "http://www.google.com" }
          "/foofoofoo" { "http://www.msn.com" }
    set redirecturl [class match -value [string tolower [HTTP::uri]] starts_with string_value_test_group ]
    if { $redirecturl ne "" } {
    HTTP::respond 301 Location $redirecturl
    Hope this helps.
