ajaykidambi_360's avatar
ajaykidambi_360
May 09, 2018
How to modify pool member status using bigsuds
How do I modify pool member status for f5? I can display the pool member & their status. I would like toggle their status to take them down during an upgrade. Suggestions please.
  • K10516 - Use disabled or forced offline, depending on your requirements. GUI or CLI should be easy to implement.
