Puli
Feb 17, 2012how to modify perl iControl script with V10.2 classes
I have been using the existing perl iControl script Query/add/delete string classes members, located here.
http://devcentral.f5.com/wiki/icontrol.perlqueryStringClass.ashx.
We recently changed the class structure to conform with version 10.2
The structure is now a key:=value pair.
name1:=value1
Can anybody share code in perl if they are able to successfully query/add/delete class entries in the new class structure in 10.2 ?
Appreciate if you can send me some sample code.
thanks,
Puli.
- Hamish
Cirrocumulus
I'm on train at moment but inhave this on my laptop (no room on uk trains for this). I will post RSN... - Hamish
Cirrocumulus
To Modify an existing entry...sub updateClass { my($classAPI, $className, %files)=@_; print "updateClass:\n"; my @members=(); foreach $filename (keys %files) { my $encode64=$files{$filename}->{BASE64}; print "updateClass: pushing [$encode64]\n"; push(@members, $encode64); } my $stringInfo = {name => $className, members => [@members]}; $soapResponse=$classAPI->modify_string_class(SOAP::Data->name(classes => [$stringInfo])); my($status,$text)=&checkResponse($soapResponse); if(($status!=1)||($text ne "OK")) { print "updateClass: status $status error [$text] from modify_string_class()\n"; exit(-1); } print "updateClass: status $status success [$text] from modify_string_class()\n"; }
To add a completely new entrysub addClassEntry { my($classAPI, $className, $classMembers, $classValues)=@_; print "addClassEntry: ($className) ($classMembers) ($classValues)\n"; my $class_members = {name => $className, members => [$classMembers]}; print "addClassEntry: calling class->set_string_class_member_data_value()\n"; $soapResponse=$classAPI->add_string_class_member(SOAP::Data->name(class_members => [$class_members])); $soapResponse=$classAPI->set_string_class_member_data_value(SOAP::Data->name(class_members => [$class_members]), SOAP::Data->name(values => [[$classValues]])); my($status,$text)=&checkResponse($soapResponse); print "addClassEntry: status[$status] text [$text]\n"; if(($status!=1)||($text ne "OK")) { print "addClassEntry: status $status error [$text] from add_string_class_member()\n"; exit(-1); } print "addClassEntry: status $status success [$text] from add_string_class_member()\n"; }
To remove an entrysub removeClassEntry { my($classAPI, $className, $classEntry)=@_; my @stringInfoList=(); print "removeClassEntry:\n"; my $stringInfo = {name => $className, members => [$classEntry]}; push(@stringInfoList, $stringInfo); print "removeClassEntry: calling class->delete_string_class_member()\n"; $soapResponse=$classAPI->delete_string_class_member(SOAP::Data->name(class_members => [$stringInfo])); my($status,$text)=&checkResponse($soapResponse); if(($status!=1)||($text ne "OK")) { print "removeClassEntry: status $status error [$text] from delete_string_class_member()\n"; return; } print "removeClassEntry: status $status success [$text] from delete_string_class_member()\n"; }
To iterate over a class and remove all entries (Using the remove funtion above)---------------------------------------------------------------------------- sub removeEntries ---------------------------------------------------------------------------- sub removeEntries { my ($classAPI, $className) = @_; my $soapResponse = $classAPI->get_string_class(SOAP::Data->name(class_names => [$className])); &checkResponse($soapResponse); @StringClassList = @{$soapResponse->result}; foreach $StringClass (@StringClassList) { $name = $StringClass->{"name"}; print "removeEntries($className): Name : $name\n"; @members = @{$StringClass->{"members"}}; foreach $member (@members) { print "removeEntries($className): : $member\n"; print "removeEntries: Removing entry\n"; removeClassEntry($classAPI, $className, $member); } } print "removeEntries($className):\n"; }
H
