How to Make Bill of Material for F5 devices.
Hello All, Can someone please tell me , how to make Bill of Material or sizing for F5 products ?
- JRahm
Admin
high-level performance data is available in the Platform Datasheet. Depending on how many software modules you'll be running on a given platform, you'll want to cross reference the aforementioned datasheet with the product matrix (pre-v11.4) or for 11.4, reference the release notes for memory requirements.
Or, you can contact your sales rep to work out the best solution for your needs.
- Pranav_73262
Hi, to start with collect following information: Throughput requirement, No. of users, No. of sessions required, SSL sessions (including 2K SSL), then features like Local SLB, Global LB, Web Accelerator etc. You can use these parameters to decide upon the Appliance & modules required; which can be used to have detailed BoQ. You also need to select support for selected appliance & modules (if any). You can get exact BoM from F5 SE once you have above requirements ready as they do not publish their Price List on partner portal.
- Vipin_01_133048
Hello Pranav, thanks for the reply..... As you mentioned in last line, "You can get exact BoM from F5 SE once you have above requirements ready" I want to know about that Tool where F5 people will make BoM. Ihat want some knowledge on that, how I will get access for that tool.....
- Pranav_73262
Hi Vipin, unfortunately there is no Tool like Cisco's DCT to make F5 BOM. You need to refer to Data sheets to decide on appliance model & mudules and then approach F5 SE to get actual BoM.
- Vipin_01_133048
Thanks Pranav for this.... Can you please help me on one more point. Can you please tell me where I will get Data sheets to decide on appliance model & mudules ?
that was already provided the in the first reply from Jason:
http://www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf
