bongso_102853
Nov 20, 2013How to log how many bytes/ packets are transferred/received within a connection
Dear all,
I have a user case that need to log the no. of packets/ bytes that are transmitted by the server within a connection (TCP/UDP).
Is there any irule command can gather this information? I want to use this command when event "client_closed"
Bong So
- Hamish
Cirrocumulus
Yeah... The IP::Stats command will give you the information you require. You can then just use HSL to send the info (Or save it to a table for later summarising etc) from the CLIENT_CLOSED event.
e.g.
when CLIENT_CLOSED { HSL::send $hsl_handle "[IP::stats packets in] [IP::stats packets out] [IP::stats bytes in] [IP::stats bytes out]" }Or similar... (Not checked for syntax obviously 🙂
H
