How to give same user access to multiple partitions using Remote Role Groups ???
Hi all,
Just wondering if it's possible to give a specific user access to multiple partitions using Remote Role Groups? When II define the Remote Role Group I can only choose between all partitions or a specific partition.
In my example I'm using remote authentication with a TACACS+ server (Tac_plus on Ubuntu Server 12.03 LTS) which is working fine with my BIG-IP VM. I tried to add a member to multiple groups within TACACS+, but it seems the user will only have access to the first partition according to the Line Order setting.
My goal at the end would be to give a user different roles for different partitions. Not just for all or one partition. So lets say user "Bob" should have the role "Manager" for Partition A and the "Operator" role for Partition B.
Any ideas how to do that? thanks a lot cheers Lukas
- What_Lies_Bene1
Don't think it's possible but if so, I'd love to know... - ccb
Employee
Don't believe this exists on LTM at this time. I think there is an RFE (Request For Enhancement) open for LTM to provide better management of multiple roles. ID382849.
