Mr_Paritchaya_7's avatar
Mr_Paritchaya_7
Mar 25, 2009
How to convert string variable to number?
I want to capture mobile number from http payload and doing mod it by 4 for select pool.
Now I'm confusing about how to convert string variable to integer or number variable for modulation.
Please suggest me about this issue.
set subid [findstr [HTTP::payload] "subscriberNumber" 0 ""]
now subid is string variable, I think that it can't mod.
set poolid exrp($subid % 4)
  • hoolio's avatar
    hoolio
    TCL variables are loosely typed so I don't think you necessarily would need to convert a string to an integer:
     % expr {7 % 4}
     3
     % expr {0 % 4}
     0
     % expr {"7" % 4}
     3
     % expr {"7" % "4"}
     3
    What types of values are you trying to mod? What issues/errors are you seeing?
    You do need to be careful in some scenarios when performing comparisons or operations though. Joe posted an article which describes some of this:
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=281
    7 - Understand Polymorphism
    TCL is polymorphic in that variables can "morph" back and forth from data type to data type depending on how it is used. This makes loosly-typed languages like TCL easier to work with since you don't need to declare variables as a certain type such as integer or string but it does come at a cost. You can minimize those costs by using the correct operators on your data types.
    * Use the correct operator for the correct type.
    * Use eq,ne when comparing strings.
    * Use ==,!= when comparing numbers
    * Use [IP::addr] when comparing IP addresses.
    If you aren't careful, things may not be what they seem as illustrated below
    set x 5
    if { $x == 5 } { } evaluates to true
    if { $x eq 5 } { } evaluates to true
    if { $x == 05 } { } evaluates to true
    if { $x eq 05 } { } evaluates to false
    Aaron
  • Hi, Aaron,
    From example below.
    I try to mod string type($subid) by 4 but I'm not sure that what type will return?
    set modid expr {$subid % 4}
    Thank you,
    Paritchaya
  • hoolio's avatar
    hoolio
    Hi Paritchaya,
    What is the value for subid? Or what is the full HTTP payload?
    I think TCL will try to convert it to an integer if you're using the variable in a mod operation.
    Aaron
