justin_48159's avatar
justin_48159
Mar 16, 2012
How to configure F5 to do SCTP and TCP conversion?
I am not sure if this is the right group to post or not.
If not, please advise me which group to post.
Thanks.
I am trying to configure F5 so it will do SCTP and TCP conversion.
F5 will connect to one far end through SCTP protocol.
F5 will also connect to other far end through TCP protocol.
F5 will do SCTP to TCP conversion in one direction.
F5 will also do TCP to SCTP conversion in other direction.
Can this be done using irules or “configuration table” or something else?
If yes, how to do it?
Thanks.
  • Has any one configured F5 to do SCTP and TCP conversion before?
    Would you mind to share some experiences?
    Thanks.
  • I'm also interested in the same functionality. It'd be great if anyone can share the knowledge.
    Not sure whether you've figured it out or not?
