Pradeep_more_10
13 years agoHow HTTPS health monitor works in f5 loadbalancer
i want to know how https health monitor works in f5 laodbalancer on non standerd port(eg:- 7005) .
can you please explane with example..
Regards
Pradeep
- nitass
Employee
doesn't it work as normal??
what is the problem? - Pradeep_more_10
It is marking node as down...so need to know how it works ...eg 1st ssl handshake ..then http... etc
how it establish connection with server...by telnet IP:port ..?
setup is like this
vip ip :7002 --back servers:7002
one i am having which is working
vip ip:443 --back server:443
I applyed....https health monitor.
name https_7002
type https
interval 5
Up Interval diable
Time Until Up 0
Timeout 16
Manual Resume no
Send String GET /alive.html\r\n
Receive String OK
Receive Disable String
Cipher List DEFAULT:+SHA:+3DES:+kEDH
User Name
Password
Compatibility enable
Client Certificate
Client Key
Reverse no
Transparent no
Alias Address *All Addresses
Alias Service Port *All Ports - nitass
Employee
so need to know how it works ...eg 1st ssl handshake ..then http... etc it is just normal https i.e. 3-way handshake, ssl handshake and then http request/response.
how it establish connection with server...by telnet IP:port ..? you can use "openssl s_client" command to test similar to telnet command for http.
e.g.
testing HTTPS with openssl
http://blog.yimingliu.com/2008/02/04/testing-https-with-openssl/
also, tcpdump/ssldump would be helpful to see what is going on. - Pradeep_more_10
in 3-way handshake, ssl handshake ...
does it requir certificate on f5 device ?...
as certificate is installed on server..
or does health monitor takes certificate from somewhere ?...
or it does not require. ?.
.as it is https...how encription and decripotion between f5 and server happen..
as monitor is like this in url from browser
https://host.domain.com:7002/alive.html.
as of now i have read access..so not able to see logs ..tcpdump/ssldump..... - nitass
Employee
there are 2 certificates in ssl handshake. one is on server which always be presented to client and the other one is on client which is sent to server only when server requests i.e. client certificate authentication.
if server does client certificate authentication, you have to import client certificate and key to bigip and set them in https monitor. otherwise, certificate and key is not needed.
as of now i have read access..so not able to see logs ..tcpdump/ssldump.....for log, you may try to enable bigd debug.
Troubleshooting Ltm Monitors by Aaron
https://devcentral.f5.com/wiki/AdvDesignConfig.TroubleshootingLtmMonitors.ashx
about tcpdump/ssldump, step should look like this. and you know private key is necessary to decrypt packet.
1/ remove https monitor from pool
2/ start tcpdump
tcpdump -i 0.0:nnn -s0 -w /var/tmp/output.pcap host x.x.x.x and host y.y.y.y and port 7002
3/ assign https monitor to pool
4/ wait until pool member is marked down
5/ stop tcpdump
to decrypt packet, you may try wireshark.
e.g.
How to decrypt SSL and TLS traffic using Wireshark
http://support.citrix.com/article/CTX116557/
hope this helps. - Pradeep_more_10
Hi Nitass,
issue is solved by just changing
to
Send String GET /alive.html\n\n
as i actualy don't know how https monitor work.
while in some R&D we found this...
can u explane what will this do ? with step by step...that will be helpful for further..
Regards
pradeep - nitass
Employee
can u explane what will this do ? with step by step...that will be helpful for further..i do not know either. anyway, if you can compare packet capture between the two monitors, i think you should be able to see what the wrong was. - hoolio
To create an HTTP 1.0 compliant request using the send string, you should use \r\n's to terminate lines and two \r\n's to terminate the GET request:
GET /alive.html\r\n\r\n
The application you're monitoring was probably responding with a 400 error with the single \n terminator you were using:
http://en.wikipedia.org/wiki/List_of_HTTP_status_codes
400 Bad Request
The request cannot be fulfilled due to bad syntax.[2]
Aaron
