How do i send an ICMP Dest port unreachable on an irule?
I have a ip forwarding virtual server that is supposed to reject packets not in my defined datagroup server_pools destined for a subset of the virtual servers we have. This functionality is working.
Below is the iRule i am using for this
when CLIENT_ACCEPTED {
Is client IP address defined in the server_pools?
if { [class match [IP::client_addr] equals server_pools] }{
forward
log local0. "Request accepted from client: [IP::client_addr] -> [IP::local_addr]"
reject
log local0. "Request rejected from client: [IP::client_addr] -> [IP::local_addr]"
However if you traceroute to the vip's they issue a ICMP time exceeded in-transit message. Instead of a ICMP destination port unreachable which lets the traceroute program know it has reached its last hop.
IP 10.0.1.10 > 10.130.65.162: ICMP time exceeded in-transit, length 36
Is there anyway to manually send this message? I know to test for UDP vs TCP i can use the following and change the protocol number.
if {[IP::protocol] == 17 }{
Any help would be appreciated.
It appears (on 12.1.1, at least) that the behavior of the
command differs based on whether address translation is enabled. When it is, as I say, an ICMP Port Unreachable message is returned (for UDP traffic). When it is disabled, the behavior you see occurs.rejectThere is no way to send a specific, explicit ICMP response from an iRule. However, a "Reject" type server will send an ICMP Port Unreachable in any case. So, you could create a "Reject" virtual server that is bound to no VLAN:
ltm virtual vs-reject { destination 0.0.0.0:any mask any profiles { fastL4 { } } reject source 0.0.0.0/0 translate-address enabled translate-port enabled vlans-enabled vs-index 6 }Then, in your iRule, instead of using
, forward rejects to this VS:rejectwhen CLIENT_ACCEPTED { if { ![class match [IP::client_addr] equals server_pools] }{ virtual vs-reject } }(Notice that the explicit
branch is unnecessary because the VS type is already Forwarding). For me, this produces an identical result for classicforward
(using UDP segments bound for random high-numbered ports), which you appear to be testing here.traceroute
- VernonWells
Employee
for UDP traffic should send an ICMP Port Unreachable message. Moreover, if the defined virtual server is not a wildcard port, then you should get a TTL Port Unreachable becausereject
chooses a random high-numbered port, and there is no listener. If the defined virtual server is a wildcard port, this should still work because of thetraceroute
. I just validated those two cases.rejectHaving said that, there are many things that could be happening here. Would you be willing to provide the Virtual Server definition? I'd also recommend performing a
on the BIG-IP to see the message flow. Something like:tcpdumptcpdump -nni 0.0 host and '(udp or icmp)'where is the IP address of the client sourcing the
.traceroute- rwendt_291390
Here you go
ltm virtual anycast-test { destination 10.0.1.0:any ip-forward mask 255.255.255.0 profiles { fastL4 { } } rules { traceroute_dst_port_unreachable } source 0.0.0.0/0 translate-address disabled translate-port disabled vs-index 88 } [rwendt@bigip01a:Active:Standalone] ~ tcpdump -Snni 0.0 host 10.130.65.162 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 96 bytes 12:58:46.856504 IP 10.130.65.162.53759 > 10.0.1.10.33455: UDP, length 32 12:58:46.856542 IP 10.0.1.10 > 10.130.65.162: ICMP time exceeded in-transit, length 36 12:58:46.867761 IP 10.130.65.162.49707 > 10.0.1.10.33456: UDP, length 32 12:58:46.867810 IP 10.0.1.10 > 10.130.65.162: ICMP time exceeded in-transit, length 36 12:58:46.867943 IP 10.130.65.162.40103 > 10.0.1.10.33458: UDP, length 32 12:58:46.868055 IP 10.130.65.162.48104 > 10.0.1.10.33457: UDP, length 32 12:58:46.868074 IP 10.0.1.10 > 10.130.65.162: ICMP time exceeded in-transit, length 36In order to see the ICMP messages i cannot add the UDP filter as it does not require a transport protocol to work.
Also traceroute relies on two ICMP messages: TTL Expired which tells it to send another probe but increment the TTL +1 and ICMP Destination port unreachable which tells it it has hit its destination.
Because the F5' is sending this message the traceroute program keeps attempting to send more probes.
- rwendt_291390
Sorry here is the output you were looking for
[rwendt@bigip01a:Active:Standalone] ~ tcpdump -Snni 0.0 host 10.130.65.162 and '(udp or icmp)' tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 96 bytes 13:08:55.570652 IP 10.130.65.162.55329 > 10.0.1.10.33455: UDP, length 32 13:08:55.570719 IP 10.0.1.10 > 10.130.65.162: ICMP time exceeded in-transit, length 36 13:08:55.582433 IP 10.130.65.162.33398 > 10.0.1.10.33458: UDP, length 32 13:08:55.582308 IP 10.130.65.162.60831 > 10.0.1.10.33456: UDP, length 32 13:08:55.582351 IP 10.0.1.10 > 10.130.65.162: ICMP time exceeded in-transit, length 36 13:08:55.582427 IP 10.130.65.162.44240 > 10.0.1.10.33457: UDP, length 32 13:08:55.582446 IP 10.0.1.10 > 10.130.65.162: ICMP time exceeded in-transit, length 36 13:08:55.588069 IP 10.130.65.162.42427 > 10.0.1.10.33459: UDP, length 32 13:08:55.587890 IP 10.130.65.162.47450 > 10.0.1.10.33460: UDP, length 32 13:08:55.587946 IP 10.130.65.162.44289 > 10.0.1.10.33461: UDP, length 32 13:08:55.590292 IP 10.130.65.162.41853 > 10.0.1.10.33467: UDP, length 32 13:08:55.590349 IP 10.130.65.162.33884 > 10.0.1.10.33468: UDP, length 32 13:08:55.590054 IP 10.130.65.162.57048 > 10.0.1.10.33464: UDP, length 32 13:08:55.590160 IP 10.130.65.162.33487 > 10.0.1.10.33466: UDP, length 32 13:08:55.590173 IP 10.130.65.162.53773 > 10.0.1.10.33462: UDP, length 32 13:08:55.590004 IP 10.130.65.162.44827 > 10.0.1.10.33463: UDP, length 32 13:08:55.590128 IP 10.130.65.162.53012 > 10.0.1.10.33465: UDP, length 32 13:08:55.590799 IP 10.130.65.162.36698 > 10.0.1.10.33469: UDP, length 32 13:08:55.590889 IP 10.130.65.162.49268 > 10.0.1.10.33470: UDP, length 32 13:08:55.591090 IP 10.130.65.162.57680 > 10.0.1.10.33471: UDP, length 32 13:08:55.601142 IP 10.130.65.162.45059 > 10.0.1.10.33472: UDP, length 32 13:08:55.601247 IP 10.130.65.162.45469 > 10.0.1.10.33473: UDP, length 32 13:09:00.607541 IP 10.130.65.162.40011 > 10.0.1.10.33480: UDP, length 32 13:09:00.607478 IP 10.130.65.162.46072 > 10.0.1.10.33474: UDP, length 32 13:09:00.607410 IP 10.130.65.162.36413 > 10.0.1.10.33476: UDP, length 32 13:09:00.607459 IP 10.130.65.162.33898 > 10.0.1.10.33475: UDP, length 32 13:09:00.607655 IP 10.130.65.162.39592 > 10.0.1.10.33483: UDP, length 32 13:09:00.607668 IP 10.130.65.162.47929 > 10.0.1.10.33485: UDP, length 32 13:09:00.607676 IP 10.130.65.162.45340 > 10.0.1.10.33478: UDP, length 32 13:09:00.607794 IP 10.130.65.162.44528 > 10.0.1.10.33487: UDP, length 32 13:09:00.607807 IP 10.130.65.162.57087 > 10.0.1.10.33489: UDP, length 32 13:09:00.607610 IP 10.130.65.162.50706 > 10.0.1.10.33484: UDP, length 32 13:09:00.607753 IP 10.130.65.162.37789 > 10.0.1.10.33488: UDP, length 32 13:09:00.607569 IP 10.130.65.162.45223 > 10.0.1.10.33479: UDP, length 32 13:09:00.607580 IP 10.130.65.162.48047 > 10.0.1.10.33477: UDP, length 32 13:09:00.607584 IP 10.130.65.162.56565 > 10.0.1.10.33481: UDP, length 32 13:09:00.607588 IP 10.130.65.162.60607 > 10.0.1.10.33482: UDP, length 32 13:09:00.607756 IP 10.130.65.162.39660 > 10.0.1.10.33486: UDP, length 32 13:09:05.615805 IP 10.130.65.162.52331 > 10.0.1.10.33494: UDP, length 32 13:09:05.615923 IP 10.130.65.162.47112 > 10.0.1.10.33493: UDP, length 32 13:09:05.615943 IP 10.130.65.162.33172 > 10.0.1.10.33496: UDP, length 32 13:09:05.616119 IP 10.130.65.162.50400 > 10.0.1.10.33502: UDP, length 32 13:09:05.616201 IP 10.130.65.162.51447 > 10.0.1.10.33503: UDP, length 32 13:09:05.615932 IP 10.130.65.162.50248 > 10.0.1.10.33495: UDP, length 32 13:09:05.616049 IP 10.130.65.162.41185 > 10.0.1.10.33497: UDP, length 32 13:09:05.616064 IP 10.130.65.162.58917 > 10.0.1.10.33500: UDP, length 32 13:09:05.615738 IP 10.130.65.162.50925 > 10.0.1.10.33490: UDP, length 32 13:09:05.615782 IP 10.130.65.162.33378 > 10.0.1.10.33492: UDP, length 32 13:09:05.615924 IP 10.130.65.162.38505 > 10.0.1.10.33491: UDP, length 32 13:09:05.616141 IP 10.130.65.162.36198 > 10.0.1.10.33499: UDP, length 32 13:09:05.616152 IP 10.130.65.162.51870 > 10.0.1.10.33501: UDP, length 32 13:09:05.616242 IP 10.130.65.162.53833 > 10.0.1.10.33504: UDP, length 32 13:09:05.616455 IP 10.130.65.162.56722 > 10.0.1.10.33505: UDP, length 32 - rwendt_291390
Ok so this was actually a lot easier a solution that i had thought previously. I created a reject vs only enabled on the frontend vlan and it works great. No iRule, no data group needed. 😄
ltm virtual anycast-protect { destination 10.0.1.0:any mask 255.255.255.0 profiles { fastL4 { } } reject source 0.0.0.0/0 vlans { VIP_Net } vlans-enabled vs-index 98
- Vernon_97235Historic F5 Account
Here you go
- rwendt_291390
- VernonWells
Employee
(using UDP segments bound for random high-numbered ports), which you appear to be testing here.traceroute- rwendt_291390
I'm running BIG-IP v11.4.0 (Build 2384.0) on this particular F5. We have about 18 F5 Bigip LTM's in service and the goal is to eventually upgrade them to 12.1.1.
On this build it wont let me enable the port/address translation on the vip. In the GUI there is no option for this so I tried in the CLI and they never get enabled.
[rwendt@bigip01a:Active:Standalone] ~ tmsh list ltm virtual anycast-protect ltm virtual anycast-protect { destination 10.0.1.0:any ip-forward mask 255.255.255.0 profiles { fastL4 { } } rules { anycast_protect } source 0.0.0.0/0 translate-address disabled translate-port disabled vs-index 96 } [rwendt@bigip01a:Active:Standalone] ~ tmsh modify ltm virtual anycast-protect translate-address enabled translate-port enabled [rwendt@bigip01a:Active:Standalone] ~ tmsh list ltm virtual anycast-protect ltm virtual anycast-protect { destination 10.0.1.0:any ip-forward mask 255.255.255.0 profiles { fastL4 { } } rules { anycast_protect } source 0.0.0.0/0 translate-address disabled translate-port disabled vs-index 96 }I tried making that reject server that isn't bound on any vlans. Then i used this ip forwarding vs to send it to the reject vs and it sends the ICMP port unreachable. However there is some weird behavior. Its sends alot of those messages now. Maybe because I cannot enable the port/address translation on it? I could send you a tcpdump of this however it was about 3000 packets for a single traceroute.
In any event thanks for the input on all of this. I think upgrading might be in order here.
