Brian_Thompson's avatar
Brian_Thompson
18 years ago
How can I add values to a data group within an irule
I'm doing reverse lookups on IP's that come in, and if they match a certain DNS I would like to append a data group that I have so that I can build a list of servers.
linsert is not working for me-
linsert $::akamai_edge2 $new_index $mask_clientIP
Anyone have any suggestions? Is this possible?
  • hoolio's avatar
    hoolio
    Using the list functions modifies what is running in memory, but the changes aren't written to the bigip.conf config file. Similarly, using an array would allow you build a set of items, but not save it to file.
    I think you'd need to use iControl to persist the changes through a restart.
    Anyone have other ideas?
    Aaron
  • does anyone have an example of using icontrol to manipulate external variables?? i'm trying to build up a cache/list of Akamai edge servers so I can throttle them when they do origin calls
    Akamai will not provide a list of edge servers because its so dynamic, so I figured I would have the load balancer generate a list and self-learn.
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    I'd try a search in the iControl codeshare & forum for an example, or post a new question on the iControl forum if nothing was found.
    iControl 9.x forum: Click here
    iControl codeshare: Click here
