Host Refused connection - Passing through F5
we have host sitting inside and refusing http/https connections from outside. we can telnet it from outside (internet) on port 443 bit when we run command https:// then not getting anything and if do telnet then gets connection refused from host.
I have standard virtual server with external vip pointed to inside host ip B.B.B.B
I have SNAT on external VS for outside communication. so flow is like below
telnet A.A.A.A port 80 trying A.A.A.A.... connected to A.A.A.A Escape character is '^]' GET /HTTP/1.1
connection closed by foreign host.
Is there anything i am missing on VS setup or any other suggestion ot recommendations please
- svs
It's really hard to help you, if you don't provide the least of information about your configuration. Could you please add the output of the following tmsh commands:
list ltm virtual list ltm poolBTW your HTTP request is not valid (maybe that's the reason why the BIG-IP denies your request). A correct HTTP/1.1 request use spaces and needs a host header.
GET / HTTP/1.1 Host: www.example.comAn HTTP/1.1 without host header does not comply with RfC and the BIG-IP silently drops or resets those requests.
- AhmedGalal219_3
if you installed a http profile you must configure SSL offloading. could you provide with VS configuration??
- youssef1
Cumulonimbus
first of did you set up ssl interception?
if yes, you need a ssl client profil and ssl server profil (if your backend listen in ssl/TLS port). you need also http profil in this case.
If no, you don't need HTTP profil, ssl server or client profil.
Last point if you have a cluster check that your floating IP have access to your backend, because monitoring is done with self IP and you can have a green monitoring and can't access to your service if you don't open flow with floating IP as source.
regards
- Korai_331784
Altostratus
ltm virtual vs_out_abc.co.nz_http { destination X.X.X.X:http ip-protocol tcp mask 255.255.255.255 pool pl_out_abc profiles { http-wan-optimized-compression { } tcp-wan-optimized { } } snatpool pl_snat_out_inet vlans { Outside } vlans-enabled } root@F5(Active)(tmos) list ltm pool pl_out_abc ltm pool pl_out_abc { members { A.A.A.A:http { session monitor-enabled } A.A.A.A:https { session monitor-enabled } B.B.B.B:https { session disabled } } monitor https } root@F5(Active)(tmos)
Tried as above with header getting same error
