Dathan_88557
Apr 20, 2011historical view of pool connection statistics
I am new to F5 and would like to know about the logging of F5 BIG IP load Balancer. We are using BIG-IP 9.4.7 Build 320.1 Final and i need to see the pool's statistics (Nodes up down with timing) of two days before. Currently from the GUI, i can only see the current active connections and it doesnt provide any historical information.
Please help me as i am new to F5.
Thanks a lot in advance.
Regards
Dathan
- hoolio
Hi Dathan,
There are some improvements coming in v11 (in beta currently).
For past versions, wee this post for a suggestion:
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/aff/32/afv/topic/aft/1176719/afc/1201367/Default.aspx
Aaron - Dathan_88557
Hi Aaron,
Thanks a lot for ur help. So without having an external graphing software like Cacti, i will not be able to see history info from the BIG IP. I will update with my management and get their acceptance to install cacti.
Thanks a lot for quick reply
Regards
Dathan
