Dan_Ecott_19303
Jan 04, 2007Help with v9 conversion of iRule
Can anyone help with this iRule conversion I need to sort out.
Here is the old V4.x rule I was using. It simply does case matching for all possible URIs.
-----------------------8<-----------------------
if (http_uri matches_regex "^/[-a-zA-Z0-9_/]{1,35}\.[a-zA-Z0-9]{1,5}$" and http_header("Host") matches_regex "^[-a-zA-Z0-9\._]{1,30}(\:[0-9]{1,5})?$") {
use pool web_seal_pool
else if (http_uri matches_regex "^/[-a-zA-Z0-9_/]{1,100}\.[a-zA-Z0-9]{1,5}$" and http_header("Host") matches_regex "^[-a-zA-Z0-9\._]{1,100}(\:[0-9]{1,5})?$") {
Can anyone help?
Thanks.
- hoolio
This should be equivalent for 9.x:if { [HTTP::uri] matches_regex "^/[-a-zA-Z0-9_/]{1,35}\.[a-zA-Z0-9]{1,5}$" \ && [HTTP::host] matches_regex "^[-a-zA-Z0-9\._]{1,30}(\:[0-9]{1,5})?$"}{ pool web_seal_pool } elseif { [HTTP::uri] matches_regex "^/[-a-zA-Z0-9_/]{1,100}\.[a-zA-Z0-9]{1,5}$" \ && [HTTP::host] matches_regex "^[-a-zA-Z0-9\._]{1,100}(\:[0-9]{1,5})?$" }{ pool web_seal_pool }
As the action is the same for either pair of conditions, you could combine them:if { ([HTTP::uri] matches_regex "^/[-a-zA-Z0-9_/]{1,35}\.[a-zA-Z0-9]{1,5}$" \ && [HTTP::host] matches_regex "^[-a-zA-Z0-9\._]{1,30}(\:[0-9]{1,5})?$" ) or ( [HTTP::uri] matches_regex "^/[-a-zA-Z0-9_/]{1,100}\.[a-zA-Z0-9]{1,5}$" \ && [HTTP::host] matches_regex "^[-a-zA-Z0-9\._]{1,100}(\:[0-9]{1,5})?$") }{ pool web_seal_pool }
Aaron
