jtostado_47719
Oct 21, 2009BIGIP 4.5 to 9.3.1 iRule Conversion
I need help converting this rule:
if (http_uri ends_with one of portal_redirect_class) {
redirect to "https://psp-portal.com/portal/server.pt"}
else {
use pool SHAREPOINT
- The_Bhattman
I suppose it can be re-written to the followingwhen HTTP_REQUEST { if { [HTTP::uri] ends_with ".jpg" } { HTTP::redirect "https://psp-portal.com/portal/server.pt" else { pool SHAREPOINT } }
orwhen HTTP_REQUEST { if { [HTTP::uri] ends_with $::portal_redirect_class } { HTTP::redirect "https://psp-portal.com/portal/server.pt" else { pool SHAREPOINT } }
I hope this helps
CB - jtostado_47719
I got error with both!
They both say:
line 1 - parse error:missing close-brace
line 2 - command is not valid in the current scope - The_Bhattman
There was syntax error on minewhen HTTP_REQUEST { if { [HTTP::uri] ends_with ".jpg" } { HTTP::redirect "https://psp-portal.com/portal/server.pt" } else { pool SHAREPOINT } }
orwhen HTTP_REQUEST { if { [HTTP::uri] ends_with $::portal_redirect_class } { HTTP::redirect "https://psp-portal.com/portal/server.pt" } else { pool SHAREPOINT } }
Keep in mind that this is an example.
CB - jtostado_47719
That did the trick. Thanks a bunch. - Sams_88783
Please help me to convert irule
else if (http_uri starts_with "/nos8" and not (http_header("SSLClientCertStatus") == "OK")) {
redirect to "https://syst.com/nos8/"
} - The_Bhattman
Hi Sumod,
you could write it is. . . else if { ([HTTP::uri] starts_with "/nos8") and !([HTTP::header "SSLClientCertStatus"] eq "OK" ) } { HTTP::redirect "https://syst.com/nos8/" . . .
I hope this helps
Bhattman - Sams_88783
Thanks Battman.It worked. - Sams_88783
Please help me with this also...i tired but its giving me error
if (client_addr == 10.1.1.1 netmask 255.255.255.255) {
if (http_uri contains one of MemberEligibility) {
use pool POOL_230_2
else {
use pool _POOL_230_1
else if (client_addr == 10.1.1.8 netmask 255.255.255.255) {
use pool POOL_230_ALL
else {
log "Using generic rule. Unexpected IP: ${client_addr}"
if (http_method == "GET") {
log "GET method used."
else if (http_method == "POST") {
log "POST method used."
else {
log "Unexpected method used."
use pool POOL_230_2
log "Eligibility request made."
else if (http_uri ends_with one of images) {
log "Image request made."
else {
use pool POOL_230_1
log "Generic request made."
} - The_Bhattman
Hi Sumod,
I suppose it would look more or less something like this untested codewhen HTTP_REQUEST { if {[IP::addr[IP::client_addr] equals 10.1.1.1] } { if { [string tolower [HTTP::uri]] contains "memberelegibility" } { pool POOL_230_2 } else { pool POOL_230_1 } } else if {[IP::add [IP::client_addr] eq 10.1.1.8] } { pool POOL_230_ALL } else { switch [HTTP::method] { "GET" { log local0. "GET method used" } "POST" { log local0. "POST method used"} default { log local0. "Unexpected method used" } } switch [string tolower [HTTP::uri]] { "*membereligibility* { pool POOL_230_2 log local0. "Eligibility request made." } "*images" { pool POOL_230_ALL log local0. "Image request Made" } default { pool pool_230_1 log local0. "Generic Request Made" } } } }
I hope this helps
I dont think so...because when i checked in Classes option i had found an entry "MemberEligibility" "String" some URL's mentioned over there.
In 9.x how we will do it in the same way.
