geoffrey_112372's avatar
geoffrey_112372
Jan 27, 2009
help with Pool_member set_connection_limit
i have difficulties to set the connection limit for a pool member I try something like this below.
Any help or example would be appreciated. thanks
  $Pool_member= SOAP::Lite
  -> uri('urn:iControl:LocalLB/PoolMember')
  -> proxy("https://$BIGIP/iControl/iControlPortal.cgi");
  @memb =
  'address' => '192.168.11.168',
  'port'=>0,
  @memberlimit=
  @memb,
  'connection_limit' => 500,
  $soapResponse = $Pool_member->set_connection_limit
  SOAP::Data->name(pool_names => [$pool]),
  SOAP::Data->name(limits => [@memberlimit] )
  • Where is the line:
    SOAP:Data->name(members => [ list of pool members ] that you would need. You have specified the pool, but not which members of that pool.
    You are setting the limit on a pool member, not the entire pool, after all.
  • The API online mention 2 Parameters
    set_connection_limit:
    Parameter Type
    pool_names String[]
    limits MemberConnectionLimit [] []
    first parameter is my pool
    the second is an array of array with a struct that describes a member connection limit.
    my member with IP and PORT
    and the connection limit
      // Member with IP and port
      @memb =
      'port'=>0,
      // Member with connection limit
      @memberlimit=
      @memb,
  • It works like that, thanks anyway
     $memb=
     'address' => "192.168.11.168",
     'port'=> 0
     $memberlimit=
     'member' => $memb,
     my @t= ($memberlimit);
     my @tab=[(@t)];
     SOAP::Data->name(limits => [@tab])
