HELITG_35878's avatar
HELITG_35878
Apr 16, 2008
Help with blocking referers
We're migrating from a version 4 appliance to version 9. We maintain various sites behind our loadbalancers. We want to use block refers linking to our content.
I have a defined a classed based on the sites
class live_sites {
"www.site.com"
"www.site.co.uk"
"www.site.de"
"www.site.eu"
"www.site.fr"
Our 4.5 the rule worked.
The version 4.5.x rule we are trying to replicate is as follows:
rule live-sites {
if (http_host == one of live_sites) {
use pool live_pool
else {
discard
I'm having problems trying to achieve the same results in version 9.
if { [matchclass http::host equals $::live_sites] } {
pool live_pool
else {
discard
Can anyone offer any assistance?
Thanks in advance.
  • hoolio's avatar
    hoolio
    If you want to validate that all requests have a host header value equal to the entries in your datagroup, the rule and datagroup you have listed should work. Just wrap the HTTP::host with square braces: [HTTP::host]. If you want to verify that the host header value value in the request contains one of the datagroup entries, you could change the "equals" to "contains".
    Lastly, if you want to verify that the HTTP Referer header contains a valid host, you could replace [HTTP::host] with [HTTP::header value Referer].
    Aaron
  • Thanks Aaron,
    When I use the square braces I get the following error. FYI, I'm running 9.4.3
    01070151:3: Rule [ir_live] error: line 2: [undefined procedure: http::host] [http::host]
    iRule listed below
    if { [matchclass [http::host] contains $::live_sites] } {
    pool live_pool
    discard
  • hoolio's avatar
    hoolio
    HTTP::host is case sensitive. Can you replace http::host with HTTP::host, and retest?
    Aaron
