Help with an I-rule rewrite
I'm trying to use an I-rule to add the http hostname in the url to the beginning of the uri then rewrite the hostname. Example:
If the client request to a VIP is https://proxy-v2.api-np-c.newapps.com/<somepath>, I want the request to the server pool to be this https://proxy-v2.api-gw-np-a.newapps.com/proxy-v2.api-np-c.newapps.com/<somepath>
I've tried this and it didn't work:
if {[HTTP::uri] starts_with "/" } {
HTTP::uri /[HTTP::host][HTTP::uri]
switch -glob [HTTP::host] {
"*.api-np-c.newapps.com*" {
set http_host [HTTP::host]
set startPos [string first .api-np-c $http_host]
set endPos [expr $startPos + 11]
set http_host [string replace $http_host $startPos $endPos .api-gw-np-a]
HTTP::header replace Host "$http_host"
After some digging, I plan to try this next:
set http_host [string map -nocase {".api-np-c" ".api-gw-np-a"} [HTTP::uri]]
As you can probably tell, I'm really new working with i-rules. Any help would be greatly appreciated!
- y-not-me
Thanks for the response. I needed it to work with *.api-np-c.newapps.com and *api-gw-np-a.newapps.com. I got it working with this, finally. I had the endPos wrong initially. It needed to be +8 not +11:
"*.api-np-c.regionsapps.com*" {
set endPos [expr $startPos + 8]
- Injeyan_Kostas
Nacreous
You could use something like this
when HTTP_REQUEST
if { [HTTP::host] equals "proxy-v2.api-np-c.newapps.com" }
HTTP::header replace "Host" "proxy-v2.api-gw-np-a.newapps.com"
set uri /proxy-v2.api-np-c.newapps.com[HTTP::uri]
HTTP::uri $uri
}Keep in mind that depending on how your web server is configured, you might also need to rewrite responses.
