kaizen10_106842's avatar
kaizen10_106842
Jun 15, 2012
Help to disable / enable LTM pool member
I am new to Icontrol using Perl.
I could write basic script to get pool status, system id etc...
For application deployment we need to disable / enable pool member. I couldn't get idea how to do it.
Can you please kindly shed light / share code on how to write a perl script to do it?
Greatly appreciated.
-Thanks.
  • Hello kaizen10,
    Just download the SDK and look at the Perl examples.
    Go to:
    https://devcentral.f5.com/HotTopics...fault.aspx
    click 'SDK Download' link.
    Go through the API documentation. That's really all there is to get you started. Maybe a tutorial somewhere...
    There are examples of 'iControl' coding here:
    https://devcentral.f5.com/wiki/iControl.CodeShare.ashx
    Are you already familiar with Perl programming?
    ~ snovakov
  • You might have to remove/re-add pool members to do what you are describing above (i.e. enable/disable pool members).
    I looked in the LocalLB/Pool and LocalLB/PoolMember interfaces, and I don't see anything like 'enablePoolMember' or 'disablePoolMember'.
    Joe, can you help with this?
  • One other possibility is the:
    LocalLB.PoolMember.set_session_enabled_state()
    method...
    ~snovakov
  • Here's an article I wrote on Graceful Server Shutdowns that illustrate the enable/disable methods
    https://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/254/iControl-Apps--04--Graceful-Server-Shutdown.aspx
    Here's another one that talks about the "three way" state toggle in the GUI, and the methods behind it:
    https://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/369/iControl-Apps--20--Server-Control.aspx
    Hope this helps...
    -Joe
