chin_15339's avatar
chin_15339
Apr 30, 2017
help required in elseif statement not working as expected
when RULE_INIT {
    set static::debug 1
when CLIENTSSL_CLIENTCERT {
Example Subject DN:  /C=AU/ST=NSW/L=Syd/O=Your Organisation/OU=Your OU/CN=John Smith
    set subject_dn [X509::subject [SSL::cert 0]]
    if { $subject_dn != "" }{
            if { $static::debug }{ log "Client Certificate received: $subject_dn"}
    if { [HTTP::host] contains "192" } {
            if { $subject_dn contains "CN=Vinit-A" } {HTTP::redirect "/vinit-A.html"}
             if { $subject_dn contains "CN=Vinit-B" } {HTTP::redirect "/vinit-B.html"}
              if { $subject_dn contains "CN=Vinit-D" } {HTTP::redirect "/vinit-C.html"}
    } elseif { [HTTP::host] contains "168" }{
             if { $subject_dn eq "" } {HTTP::redirect "/Certmissing.html"}
  • Hi,
    if you redirect to
    /vinit-A.html
    , redirect only
    URI, else, the request to
    /vinit-A.html
    will be handle by the irule and will redirect to
    /vinit-A.html
    and use
    switch
    instead of
    if / elseif / elseif/ elseif
    when RULE_INIT {
        set static::debug 1
        if { [HTTP::host] contains "192" && [HTTP::host] && [HTTP::host] equals "/" } {
            switch -glob -- $subject_dn {
            "*CN=Vinit-A*" {HTTP::redirect "/vinit-A.html"}
            "*CN=Vinit-B*" {HTTP::redirect "/vinit-B.html"}
            "*CN=Vinit-B*" {HTTP::redirect "/vinit-C.html"}
        } elseif { [HTTP::host] contains "168" && [HTTP::host] equals "/" }{
  • thanks Stanislas but the rule is still not working when there is no client certificate presented I want the page to redirect to /Certmissing
    • stan_piron's avatar
      stan_piron
      Can you explain what are 192 and 168 hostnames? (it make me think about 192.168.x.x).
      when RULE_INIT {
          set static::debug 1
          if { [HTTP::host] contains "192" && [HTTP::host] && [HTTP::uri] equals "/" } {
              "" {HTTP::redirect "/Certmissing.html"}
          } elseif { [HTTP::host] contains "168" && [HTTP::uri] equals "/" }{
    • chin_15339's avatar
      chin_15339
      yes that is correct Stanislas we are trying this in our staging environment
      chin_15339
      Hi Stanislas I tried your updated irule but sorry no luck it doesnt work as expected
      the redirects /vinit-A.html and /vinit-C.html and B works as expected but the missing Cert does not work
