Dixit_18200's avatar
Dixit_18200
Feb 23, 2010
Help needed for irule issue
I have setup two irules for http to https redirection
1st for redirecting the below websites
http://www.acbg.com/ucc
http://www.acbg.com/saleshub
http://www.acbg.com/cct
and the irule i have appiled for this is as below
if {[HTTP::uri] ends_with "/ucc"} {
HTTP::redirect "https://microsite.accenture.com/ACBG/Solutions/UCandC/Pages/default.aspx"
elseif {[HTTP::uri] ends_with "/saleshub"} {
HTTP::redirect "https://microsite.accenture.com/ACBG/Pages/SalesHub.aspx"
elseif {[HTTP::uri] ends_with "/cct"} {
HTTP::redirect "https://microsite.accenture.com/ACBG/Solutions/CustomerContact/Pages/default.aspx"
2nd irule for redirecting below websites
http://www.acbg.com/saleshub/dc
http://www.acbg.com/saleshub/ins
http://www.acbg.com/saleshub/ucc
http://www.acbg.com/saleshub/cct
http://www.acbg.com/saleshub/os
if {[HTTP::uri] ends_with "/saleshub/ucc"} {
HTTP::redirect "https://microsite.accenture.com/ACBG_SalesHub/solutions/Pages/Outsourcing.aspx"
elseif {[HTTP::uri] ends_with "/saleshub/cct"} {
HTTP::redirect "https://microsite.accenture.com/ACBG_SalesHub/solutions/Pages/CCT.aspx"
elseif {[HTTP::uri] ends_with "/saleshub/dc"} {
HTTP::redirect "https://microsite.accenture.com/ACBG_SalesHub/solutions/Pages/DataCenterSolutions.aspx"
elseif {[HTTP::uri] ends_with "/saleshub/ins"} {
HTTP::redirect "https://microsite.accenture.com/ACBG_SalesHub/solutions/Pages/InfrastructureSolutions.aspx"
elseif {[HTTP::uri] ends_with "/saleshub/os"} {
however for the below websites the irule is not working properly. When i remove the first irule the below redirection works perfecrtly. Please help
  • Hamish's avatar
    Hamish
    Is there anything else in the iRules? Or are they just a single event? Two iRules shoould both fire, one after tjhe other, unless the first has a discard, drop or event statement...
    Can you put a logline in the start of the event to indicate whether they're being called, and what the URI is
    (Oh. I'd probably re-write the iRules to do a lookup in a class rather than a whole lot of if/then/elseif's... It'll scale better. e.g. (I was going to write one, but the findclass wiki page has it as an example already)
     class URIredirects {
       "/dir1/dir2/dir3/ http://somehost.somewhere.com/redirect_target.html"
       "/dir4/dir5/dir6/ http://someotherhost.nowhere.com/redirect_target.html"
       set location [findclass [HTTP::uri] $::URIredirects " "]
       if { $location ne "" }
         HTTP::redirect $location
  • hoolio's avatar
    hoolio
    I'd guess this is an issue with trying to send a redirect from both rules on the same request. /var/log/ltm should show a runtime TCl error about multiple redirect invocations. For example, http://www.acbg.com/saleshub/ucc is going to match the first iRule check for a URI ending with /ucc and the second iRule check for /saleshub/ucc.
    Hamish's suggestion of using a datagroup and the findclass command is a good one if you don't need to use wildcards. If you do need to use wildcards, you could use a switch statement instead of a datagroup and findclass or the if/elseif/else chain. It would be idea if you could combine the iRules into one to ensure that only one redirect is attempted per HTTP request.
     switch -glob [string tolower [HTTP::uri]] {
        "*/saleshub/ucc" {
        "*/ucc" {
        default {
            Take some default action
    No matter what though, you'll need to pick which matches you want take priority for each URI stem (/saleshub/ucc or /ucc, etc).
    Aaron
  • Hi Aaron/Hamish,
    Thanks for the reply.
    Getting the following error when trying to apply irule provided by Aaron
    01070151:3: Rule [Vanity-Sales] error:
    line 1: [command is not valid in the current scope] [switch -glob [string tolower [HTTP::uri]] {
    "*/saleshub/ucc"
    { HTTP::redirect "https://microsite.accenture.com/ACBG_SalesHub/solutions/Pages/Outsourcing.aspx" }
    "*/ucc"
    { HTTP::redirect "https://microsite.accenture.com/ACBG/Solutions/UCandC/Pages/default.aspx" }
    line 1: [command is not valid in the current scope] [string tolower [HTTP::uri]]
    line 1: [command is not valid in the current scope] [HTTP::uri]
  • hoolio's avatar
    hoolio
    Sorry, that was a code snippet. It would need to be in the HTTP_REQUEST event:
         "*/saleshub/ucc" {
         "*/ucc" {
         default {
    Aaron
  • Hey Aaron,
    Can you plese let me know who i can combile two irules in to one? at present i have created two switch irules for /ucc and /cct can you please let me know how i can combine these two into one?
  • Just extend Aaron's example:
          "*/saleshub/ucc" {
          "*/saleshub/cct" {
          "*/ucc" {
          "*/cct" {
          default {
    You just want to make sure your saleshub matches occur first in the switch so your matches occur correctly for /saleshub/*
