Hari_Ganesh_352
Jun 11, 2007Help in application access and portal access
Hi ,
One of the requirnment in our client place is as soon as they login by the user name and password in the firepass ,as per their group configuration the application and the portal logins need to get launched automatcally ,
can any one help me out on this ?
Thanks & Regards
Hariganesh
- PC_46752
I really doubt if this would be possible... the user normally has to visit his homepage and click on the resources to open in a new window.
Prabhu - PC_46752
Hari, on a second thought, I do see an option... just go thru the help file under network access, and you may find an option to set N/w access to auto-launch with a delay after you've logged in... and you could configure new programs to lauch after the n/w access is established. This may not answer your question fully, but you may find this useful as a start point. - Mike_Ho
Cirrus
If you look at the Application Access -> App Tunnels Favorites you should be able to choose "Autolaunch based on endpoint protection" and create an endpoint protection policy for all affected users and apply it to the resource group. - mal_57091
Hi Harri,
Yup Michael has it. You can autolaunch AppTunnels based on endpoint protection. However, if you want to 'autolaunch' a Portal Access favorite there really isn't a way to do this. The option here is to use the Intranet Webtop feature which effectively redirects the user, after logon, to the configured internal URL without showing the traditional FirePass Webtop.
Cheers,
Mal
