kleis_oenema_67's avatar
kleis_oenema_67
Jul 06, 2007
help implementing i-rules
I just need to compose an i-rule to impose secure loging. At present it works fine in a dx box from junper with a so called ptc rule. The ptc rule is rewriting a part of the contents. This has now to be done by a big-ip version 9.3x.
the first I rule applies to http to redirect to https this works fine.
rule for http
if { [HTTP::uri] contains "/Logon/ProcessLogon.asp?iscontained=Yes"} {
HTTP::redirect "https:://"[HTTP::host][HTTP::uri]"
} elseif { [HTTP::uri] contains "interop" } {
pool HFM-Prod-interop
} else
{pool HFM-Prod }
rule for https
if { [HTTP::uri] contains "../home/home.asp?iscontained=Yes" }{
HTTP::redirect "http://[HTTP::host][HTTP::uri]"
} else
{pool HFM-Prod }
so far so good. However the https rule should do more and replace content data
to this rule the following should be added. I give first the ptc rule as applied in the redline
PTC: content contains "" then replace content term ""
in the above lines the "\" are escapes for the redline to ignore the next character.
I suppose this should be used in the big ip as well for " and ( ) do have meaning in parsing.
in simple language the following should happen
if the content contains:
then replace the content with:
In the above I took away the escapes needed for the redline
Who can help me do solve this problem
  • I would apply a stream profile against your https virtual:
    profile stream replace_content_1 {
       defaults from stream
       source ""
       target ""
  • I tried to implement the given rule but to no avail, I keep getting errors.
    Next I tried to implement the next rule but it generates the error in the I rule editor "line 9: [unknown event (STREAM_MATCHED)] [when STREAM_MATCHED {"
    the rule I tried is given below.
    if { [HTTP::uri] contains "../home/home.asp?iscontained=Yes"} {
    HTTP::redirect "https:://[HTTP::host][HTTP::uri]"
    pool hfm-prod-interop
    } else
    {pool hfm-prod }
    if{ [STREAM::match] contains ""} {
    STREAM::replace ""
    who knows the answer
