random letter generator
Problem this snippet solves:
This iRule demonstrates how to generate a string of pseudo-random letters. rand() doesn't generate cryptographically secure output. If you need this, use the CRYPTO commands.
Code :
when RULE_INIT {
# Number of random letters to generate
set count 100
# Create a list of the letters indexed 0 through 25
set letters [ list a b c d e f g h i j k l m n o p q r s t u v w x y z ]
# Initialize a variable to store the random letters in
set random ""
# Loop through X times where X is the number of random letters to generate
for { set i 1 } { $i < $count } { incr i } {
# Generate a random number between 0 and 1, using rand()
# Multiply that by 26 to get a number representing a letter
# Use int to trim off the decimal value
# set rand [expr { int (rand() * 26) }]
# append random [lindex $letters $rand]
# Or in one command:
append random [lindex $letters [expr { int (rand() * 26) }]]
log local0. "Random letters: $random"
}Published Mar 18, 2015
Version 1.0hoolio
VP of Solutions at WorldTech ITNo CommentsBe the first to comment
