FTP Monitor not working , need Logs for debugging in BIGIP 2000
i have created a FTP monitor, but it is in offline state. i could see from the FTP server, that LB monitor is able to login to the system successfully. but the monitor state is down always. my understanding is in FTP monitor it will login to the FTP server and write a test file to it.
so in my case i am sure that login is successful, but not sure whether the file creation had any problem or not ? can any one please let me know how/where to check necessary log files ?
- Thomas_Gobet
The monitor is not here to create any file on your ftp server. But it will check if the path or file exists.
Just change your monitor with an available file and your virtual server will be up.
- Tilden_138221
Thanks Thomas !!
I found the issue in the System, issue cause due to FTPaccess restristion ,, i found it by enabling the debugging log. we can enable the debug log from the Web interface and in the server box we can find the log in /var/logs
