f5learning9's avatar
f5learning9
Dec 26, 2023
Forwarding IP recommendations - using destination /32
Hello team,
I am looking for any information related to "how to" create Forwarding IP with destination /32 address, recently I had an issue with a backend server, I created the Forwarding IP and destination was that server IP, well the server rebooted automatically for patches, then the F5 took over that IP (didn't realize a virtual address is automatically created under virtual address list) with ARP and echo enabled. so the server was added to one pool, because of that , the pool went down.
Do you know if recommended action is use /24 or different subnet than /32 when creating Forwarding IP, or disable ARP and echo for Forwarding IPs.
