Doubstar_24121
Nov 16, 2011"FirePass SSL/VPN VE 7.0 and Bring Your Own Device"
Hi all,
I have a question about the BYOD hype and i have to say that i am thinking about how F5 especially FirePass VE 7.0 (which is the one i am using right now) does or have a compatibility for it? which means; is it possible to setup FirePass to create differences between known devices and unknown ones which also applies to known and unknown users ?
is somewhere here some publication or documentation on this matter ?
Thank you very much.
Cheers,
---Said
- Mike_61719
Cirrus
I would recommend installing a package or two to check for registry entries. If you don't want to do that, check for certificates would be the best choice. - Doubstar_24121
Hi Mike,
thanks for your reply.
the matter is that beforehand you'll never know who is trying to access your network, that' s the concept of BYOD.
i am wondering if it possible to setup a policy in FP Access Control List so that you can provide external unknown users and devices limited access to Internet outside your LAN.
Cheers,
Said
