C4sp3R's avatar
C4sp3R
Jan 08, 2020
F5's monitor ansible module
Is there an elegant way to export/save the different types of monitors locally?
Because currently it seems you have to save the different types of monitors individually, e.g.:
- name: Saving HTTPS monitors
    copy:
      content: "{{ item | to_nice_yaml }}"
      dest: ./f5/{{inventory_hostname}}/monitors/https_monitors/{{item.name}}.yml
    loop: "{{results.https_monitors }}"
  - name: Saving HTTP monitors
    copy:
      dest: ./f5/{{inventory_hostname}}/monitors/http_monitors/{{item.name}}.yml
    loop: "{{results.http_monitors }}"
  - name: Saving ICMP monitors
    copy:
      dest: ./f5/{{inventory_hostname}}/monitors/icmp_monitors/{{item.name}}.yml
    loop: "{{results.icmp_monitors }}"
Apart from that a small sidenote (maybe i'm grasping the concept of ansible wrong), but wouldn't it be better to introduce a key with the type of monitor instead of creating a dictionary for every type, as the current approach makes automatic iterating hard if the types change for some reason.
